TwinTurbo.NET: Nissan 300ZX forum - The only thing that strikes me would be a faulty TPS
en5
on April 20, 2008 at 7:28 PM
high idle - 1800 RPM question
posted by The Devils Z
on April 20, 2008 at 06:43 PM
Because nothing should increase the voltage to the TPS unless the throttle increases, as far as I know.
The Devils Z
18:43:12 04/20/08
Try checking the vent tubes attached to the valve covers
Agner.S(CT)
19:27:16 04/20/08
The only thing that strikes me would be a faulty TPS -
en5
19:28:56 04/20/08
2nd. Sometimes the connector for the switch part of the
MixManMash
12:04:48 04/21/08
Wouldn't the TPS voltage be off at idle at that was the
The Devils Z
12:38:43 04/21/08
looks like you may be right on ... (n/m)
The Devils Z
14:43:03 04/21/08
Re: high idle - 1800 RPM question
300twinz (satx)
19:31:49 04/20/08
i had this issue, although it was due to
inf
19:37:48 04/20/08
Is your Air Regulator working?..vacuum leak? (n/m)
Audioquest
19:42:22 04/20/08
Re: Is your Air Regulator working?..vacuum leak?
The Devils Z
19:48:47 04/20/08
yes --the Throttle body linkage is one of the first things
The Devils Z
19:47:48 04/20/08
mine snapped back too
inf
21:02:56 04/20/08
try slowly letting off of the cable to see if it returns
gt300zxtt
22:53:40 04/20/08
using pic from faq
gt300zxtt
22:58:46 04/20/08
question ..if it was the TB linkage wouldn't the RPM
The Devils Z
06:04:11 04/21/08
not sure
gt300zxtt
09:03:51 04/21/08
possible solution ...the TPS in closed mode --which means
The Devils Z
14:17:54 04/21/08
Hey Devil, had the same weird problem too...
escturbo
06:45:11 04/22/08
look here ..
The Devils Z
07:50:24 04/22/08
SOLUTION FOUND ... it turns out idiot me put one of the
The Devils Z
20:34:00 04/22/08
